跳转到主内容
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 个问题 查看全部
Replaced IPad 2 LCD now it won't power up.
Hi I replaced the LCD, digitizer, and wifi cable on my iPad 2. It went pretty smoothly but I cannot power the iPad up now (even with the old cracked LCD). All the connections are tight and the battery is charged. The new digitizer glass came with it's own home button already in place. Any ideas for me? Thanks so much for your help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
已选择的解决方案
I got it to turn on. I plugged it into the computer, pressed the home button and the power button at the same time, and the apple in the center of the screen appeared. Thrilled it works!
这个答案有帮助吗?
得分 1
2条评论:
Thank you so much!!! This information was invaluable!! =)
完成的
My ipad 2 was doing the same thing. The backlight on the screen was not coming on. This worked.
完成的
添加一条评论
see this video they explain it at the end of the video.
这个答案有帮助吗?
得分 0
添加一条评论
for me not work....is dead!!!!
这个答案有帮助吗?
得分 0
添加一条评论
One good way to fix this if the reset didn't work is to disconnect the batteries for 30 minutes then connect it back... What happens sometimes is that your software doesn't realise (for stupid reason) that the lcd is supposed to be off and it gets all mixed up. That solved my problems 3 times already.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Carrie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 7,815
