跳转到主内容
Repair guides and support for your Philips TV.
220 个问题 查看全部
Philips 60pfl6008h/12 has standby 3.5V, but cannot turn on
My Philips 60" TV just cannot turn on,
Standby pwer is ok, get 3.5V on pin 9 and 10, the LED light just blinking non stop.
like to know what is the problem and how to resolve it.
Update (12/24/2022)
I have connected back the SMPS board to the chassis, and checked all the supplies are normal on the IM90 connector. there is also a 24V to the back light LED driver baord and proced 65VDC too.
The front LED light blinking, the sequence is continues blink twice, and repeat.
Please advice how to repair it, thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Can you upload pictures of the circuit boards in the TV?
完成的
添加一条评论
1个答案
Hey,
I had the same issue ... The Phillips 6000/7000/8000 Models have cooling problems the CPU gets very hot and overheats now there are little pins whitch are broken because they broke between the Time were its turned off and cooled up. Now you have to connect the broken pins back to the CpU so, take the MOBO in your cooker and turn it to 230 Degrees for about five Minutes then it should work fine...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Curtis Choy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 54
