跳转到主内容
任天堂于2019年9月20日发布了在Switch系列中更加实惠、且更纯粹的掌上游戏机——Nintendo Switch Lite,它有着一体式的手柄设计以及更小的屏幕。
175 个问题 查看全部
power button stopped responding after joystick replacements
Hi! I was replacing the joysticks on my little sisters switch lite, and I've come across an issue. after I replaced the left joystick, everything worked fine, but after the right joystick, the power button refuses to respond(and yes, I have replaced the power and volume buttons
what's going on here? to be clear, I can jump start the system with a multimeter, and the volume buttons do work, just not the power button.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi Bella,
Okay, lets do a little brainstorming here.
The volume/power buttons are connected via a small flex cable going to the circuit board on the left side of the battery (right side if you're looking at it from the back with the case opened up. Given that you said everything worked after replacing the left joystick, let's assume everything was good at that point.
Now to do the right joystick you have to remove the motherboard. The only connection between the motherboard and the daughter card is that somewhat fat flex cable that starts right above the battery connector and goes along the bottom of the battery to the left side daughter card. You do have to disconnect that to remove the motherboard in order to access the right joystick. so my guess is that's where the trouble lies. You'll need to check the cable itself for any kind of damage; it will probably be small if the power button is the only thing being affected. Look along the length of the cable, but especially the contacts at the end where it plugs into the motherboard.
In addition, it's possible one of the pins on the motherboard connector is bent out of place or broken. A bent pin may be able to be straightened with a pair of fine tip tweezers, but a broken one will require the replacement of that connector, a difficult job for an experienced DIY-er, but should be relatively straight-forward for a repair shop.
Look at everything I've mentioned with a magnifying glass and a bright light. If you don't find a problem, go ahead and clean the connector and both ends of the flex cable with 90% or higher isopropyl alcohol (don't use the 70% rubbing alcohol we all have around the house) and reassemble. Check if that's made any difference and let us know what you find.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Bella Marie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 45
总计 769
