跳转到主内容
惠普台式机维修指南。
351 个问题 查看全部
问题已关闭
"Cannot access the specified device, path, or file" Windows XP
On this HP Desktop, the computer gives the above error message in the description when trying to access most of the programs and files. It may have something to do with the AVG virus protection locking the computer down, however I cannot access that program to either uninstall it or remove the restriction temporarily.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
It does sound like the programs you are trying to access are not physically present.Right click on one of the desktop items, click on property. There should now be the property window open up. check on >shortcut>target> in there you should see where the file is actually located. Make sure that you have a drive letter that is physically there. You may have a computer that was either network connected or had external drives with the program files. XP will give you that particular message anytime it can not find the files, it does not sound like your virus program is locking down your drive. you would definitely get a different error message.
这个答案有帮助吗?
得分 0
添加一条评论
If you believe AVG is the cause of the problem you can boot into safe mode. From safe mode you should be able to disable or uninstall AVG. To get to safe mode most computer require you to tap the F5 or F8 key. Your problem also sounds like you computer could be infected with a virus or malware. You may want to boot into safe mode and run a virus and malware scan to see if that corrects the problem.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,395
