跳转到主内容
Gaming laptop released in 2014 with an Nvidia 860M graphics card and a 15.6" display. Updated in 2015 with 960M graphics.
“Install Windows” Restart Loop
I was attempting to wipe my Y50-70 laptop when it failed mid-wipe and now it’s displaying “Windows installation cannot proceed. To install windows, click “OK” to restart the computer, and then restart the installation.” When I press this, it goes through the Lenovo loading screen and then the message pops back up again. I’ve tried changing it to a legacy reboot, but that didn’t work. Is there any way to factory reset or reboot it by force?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Hi lillie, I am not very clear here. What were you actually trying to do and how did you do it? Reinstall Windows or just wipe the hard drive of everything - as in reformat?
完成的
@aactech I was trying to wipe it of everything since the laptop was being given to me from a friend. While wiping it, it needed to reinstall windows but it seems to have failed.
完成的
添加一条评论
1个答案
最有帮助的答案
@lillieo
How did you try to wipe it?
Did you do go to Settings > Update & Security > Recovery. Under the Reset This PC heading, click Get Started and then Remove Everything?
If there were corrupt files or a virus on your friends machine this may be why it did not work.
The best way is to download the install file from Microsoft and choose the make USB flash drive install or words to that effect.
https://www.microsoft.com/en-us/software...
You will need a clean USB flash drive and another Windows 10 computer.
When the install asks for the Product Key just click near the bottom of the window on "I don't have a product key." As it is digitally registered Windows will just put it in automatically later on. This will probably work best if you connect the laptop to your router with an Ethernet cable. just incase there are Wi-Fi driver problem at first. If you don't have one they are about $10 at a local computer shop.
If any question - just ask.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Lillie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 281
