跳转到主内容
A 6'' 1080p budget phablet available through T-Mobile and manufactured by Coolpad. Model number C3701A. It was released in August 2017.
5 个问题 查看全部
My phone keeps saying that it's charging when it's not
Sorry for incorrect phone model, but I couldn't find my phone model in the list of models, so I just went with the one that most closely resembles my phone. I have a T-mobile Revvl 4, and the phone says that it's charging when it's not and the screen just randomly turns black, and it's had issues like this for 9 months. I have to constantly turn it off and then back on again to get it to temporarily work again. However, then the screen just turns black again, and the issue continues. My phone briefly stopped having the issue for about 2.5 months. On December 14, it was raining and only a little bit of rain got on my phone, but not enough to cause any water damage. I'm not sure if it's because of the rain or not, but now it's going back to saying that it's charging even when it's not, and the screen is randomly going black again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
so my only guess is that the fuses on the board that take in the charge and send it to the main chip are faulty and the screen randomly turning off I don't know much about that try updating the phone see what happens
这个答案有帮助吗?
得分 0
添加一条评论
@kaylani could be a battery issue. I would definitely start with that. Also, check the charging port. Make sure the are no bend pins, corrosion or debris that are creating any obstruction. Check your circuit boards for corrosion and other visual cues that something does not look right. You can always post images with your question. That way we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kaylani Thomas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 160
