跳转到主内容
The iO, released in 2020 is an electric toothbrush by Oral-B. It is able to connect to your smartphone via Bluetooth and gives you realtime 3D teeth tracking. Model: Oral-B iO 9
12 个问题 查看全部
Can't start after replacing battery
Hi, why my oral b io doesn't work after battery replacement? The guide is fool proof however, something goes wrong.
Thanks for your help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
Hi @juanpulag,
Did you put the battery in the correct way? Maybe double check.
Did you charge the battery first after installing it, before attempting to turn on the toothbrush?
完成的
What battery type did you replace with? Do you have a multimeter?
完成的
@andrewsawesome Hi Andrew, thanks... I don't have a multimeter, so I can say that even the original battery doesn't start the brush.
What can I do with a multimeter? Thank for your answer....
完成的
@juanpulag I was going to ask you to check the voltage of the battery with a multimeter.
完成的
@jayeff hi, neither new and old battery works, the brush just shut down permanently... So sad, that's was something easy to solve "was"
完成的
显示更多的2条评论
添加一条评论
1个答案
已选择的解决方案
Sorry to be late to the party, but a german user just posted a comment with the same problem and the solution: He managed to reset the io via the app and it works flawlessly since then.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Diego 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 24
过去 30 天: 84
总计 1,641
