New Front does not fit exactly
After i installed the new front, everything worked like expected, but when i push the display at the edges it moves a bit back.
Thats not as intended...
is there a chance that some of the little rubber spacers have gone missing from around the frame edges?
this is about all i can think of
这个答案有帮助吗?
I will check that. But thx for your help.
If yes? Where can i buy them? The new display i installed has none of them.
If your not familiar with the parts then you need to know that not all replacement parts come with the outer screen bezel. Look at your old part you will see a thin plastic edge that flipped over you see the the bezel frame attached with the two sided LSC-300 adhesive. Without the bezel the screen will seem to be slightly smaller than it should. Check to see if that could be the issue.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 532
