跳转到主内容
沃克斯豪尔汽车的修理和支持指南。 成立于1903年的英国汽车品牌。
Piston number 2 is misfiring
Hi. I have a problem.
My opel Astra G 1.6 16V has a problem, piston number 2 is not burning fuel/ gas. Whenever i test spark.. It's there, but the plug is covered in gas. What could be the problem. How do I fix it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Chris,
How are you testing the spark? If the spark plug is working, it shouldn't be soaked in gas, obviously. If you're pulling the wire off the plug and verifying you've got spark at the end of the spark plug wire, that doesn't guarantee the spark is getting through the plug into the combustion chamber. Remove the spark plug from the cylinder and plug it into the plug wire then ground the threads against the block and crank the engine over. You should see spark between the electrode and the tip of the plug. If you don't see any spark, try swapping the plug with another cylinder and see if the misfire follows the plug. If that happens, you've got a spark plug that's damaged internally and not conducting the spark from the wire to the electrode.
If you do get spark and the misfire stays on cylinder 2, the next step would be to do a compression test. Without compression only a small amount of the fuel/air mixture is going to be present on the compression stroke and not much is going to happen when it sparks.
Try those things and let us know what happens; if you have a good plug and good compression we'll try and figure out what to do next.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chris Malaza 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 169
