跳转到主内容
任天堂3DS XL 2015在市场上被称为新任天堂3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
338 个问题 查看全部
Why is my 3ds not turning on?
it doesnt have water damage so i dont know why it wont turn on. it seems to be stuck in sleep mode
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
what makes you think it's in sleep mode?
完成的
添加一条评论
2个答案
Could you elaborate a bit more? Does it show a red light, or a blue light, does it have custom firmware ect.
这个答案有帮助吗?
得分 0
添加一条评论
It would be good if you could post some more information about what is going on with your DS. For example when you try to turn it on do any of the LEDs such as the power light turn on? Does the charging LED turn on when it's plugged in? Are you running some custom software on your DS? Do the screens remain completely black or do they
If you plug your DS on and none of the LED lights turn on that could mean that your charger is bad and you need to try charging it with a different charger.
If your charger isn't the issue and the lights still don't turn on with a good charger plugged in that could mean that you need a new battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eliyahu Abitbol 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 29
