跳转到主内容
The Radeon RX 460 is a graphics card by AMD, launched on August 8th, 2016. Built on the 14 nm process, and based on the Baffin graphics processor, in its Baffin PRO variant, the card supports DirectX 12.
1 个问题 查看全部
How to repair it?
How to repair Radeon RX 460? No signal to monitor, I played Starbound and when i teleported to ship, i saw white lines, i ignored em and she died, i want her back.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
添加一条评论
1个答案
It's difficult to say exactly how to repair a Radeon RX 460 without more information, but there are a few steps you can try that may help:
  1. Make sure that the cables connecting your monitor to your graphics card are securely plugged in at both ends.
  2. Try unplugging the power cables from your computer and plugging them back in to reset the hardware.
  3. Check the settings on your monitor to make sure it is set to the correct input source (HDMI, DisplayPort, etc.)
  4. If your graphics card has a separate power cable, make sure it is securely plugged in.
If these steps don't help, it's possible that your graphics card has failed and will need to be replaced.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marian-Gabriel Ionita 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 135
