跳转到主内容
Vivo 手机维修指南,2009年Vivo 手机公司在中国成立。
47 个问题 查看全部
vivo nex dual display black screen problem
My vivo nex dual display phone has been shut down for a while, There is no problem in the screen that can make it to go black. When i charge it the phone gives me vibration as I try to open It but with no display so please help me I don't know what to do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hey this problem happens with water damage sometimes the connectors can get corroded or ripped if you didn’t water damage it I see that probably the phone got dropped and the cable got disconnected but that you say it vibrates
这个答案有帮助吗?
得分 0
4条评论:
there is damage by any means nor water thing I was in the road and the battry drained and shut down at that time and i had no cable access to charge it so i didn't charged it upto 1 hour at minimum but when i get home and try to open my phone the scrren stays black with vibration i tried hard reset but not helpful also the cables are fine i have seen it there is no damage in the hardware part even technicians can figure it out the problem....what do u think It would be??Is it battry problem that may be the dual display uses 2 screen with one battery that the battery is soooo drained It didn't have enough power to power it on?
完成的
You’re confusing me a bit I meant the cables on the inside
完成的
what is the thing that is confusing u?
完成的
Try chargeing with a diffrant charger
完成的
添加一条评论
添加你的答案
aman tadele 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 66
