跳转到主内容
My dirt devil will not start or charge
I get a blue light otherwise it’s dead. It won’t charge or start. What’s my problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@sparks203, First make sure the charger is working (use a DMM, digital multimeter) and outputting the correct voltage.
The first suspect in cases like this, is always the battery. A bad p / dead battery is the primary cause of no charge and no power. Try opening the Dirt Devil up, to gain access to the battery, and then test the voltage of the battery.
You didn’t specify your model, but here is a link to p25 of the operating manual of a Dirt Devil. It shows which screws to remove to get access to the battery.
这个答案有帮助吗?
得分 1
2条评论:
I have used it once. Plugged it in a good outlet to charge. Checked everything Worked for about 10 minutes. then nothing.
完成的
carol larocque, If you bought it new, and it won’t take a charge, I’d say take it back under warranty, because you might not want to void the warranty. If you bought it a “long” time ago, and it’s been sitting on the shelf, the battery could have gone dead.
完成的
添加一条评论
Plugged it in once after usage. Worked for about 10 -15 minutes. All charged and cleaned. New. Second time using.
这个答案有帮助吗?
得分 0
1条评论:
Had my old Dirt Devil for 10 yrs or more. No Problem. Gave it to my daughter. Still works. Used me new one once. Plugged it in, checked everthing. Still not workinng.
完成的
添加一条评论
添加你的答案
Susan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 36
过去 30 天: 199
总计 749
