跳转到主内容
A festive yuletide staple.
10 个问题 查看全部
entire pre-lit Christmas tree won't light
entire pre-lit Christmas tree turned off and won't turn back on”
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
What model/brand Christmas tree?
完成的
It is a 9 foot Frontgate tree, its 5 years old, I don't know the model.
完成的
I changed the fuse it the tree plug ( took 225 5A fuse). it worked!! However, the tree still blows a Fues after a day or two. I just can't figure out why it started doing this, after 5 years. Help!
完成的
添加一条评论
1个答案
最有帮助的答案
Hi Donna,
Just because it's a pre-lit tree doesn't mean the lights are any different than any other Christmas light string, so check out the guide to fixing broken Christmas lights.
Fixing Broken Christmas Lights - iFixit Repair Guide
这个答案有帮助吗?
得分 2
3条评论:
This is a 5 year old pre-lit tree, and I did replace all the bad bulbs,, which took 2 hours last weekend. It was lit, and then (like a switch was flipped), the entire tree turned off. I checked the outlet, and it is good. Its something with the tree, which is completely decorated :(
完成的
Same here. Lights started flickering and wouldn’t turn off with foot controller. Had to unplug then lights wouldn’t work.. one of them!
Nancy
完成的
meant to say none of the lights work
Nancy
完成的
添加一条评论
添加你的答案
Donna Dubbs 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 4
过去 30 天: 5
总计 317
