跳转到主内容
Fiber and textile material that is worn for style, safety, and protection from the elements.
309 个问题 查看全部
Are syntetic baselayer fixable?
Hi, there is no information how to fix a hole in syntetic baselayer. couldn't find it in i-net either.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
This question was migrated from https://meta.ifixit.com/Answers.
完成的
Wasn't helpful. May I get a straight link to this question?
完成的
添加一条评论
1个答案
最有帮助的答案
It may be possible to fix a hole in a synthetic baselayer, depending on the size and location of the hole and the type of synthetic material used in the baselayer. Here are some possible methods for fixing a hole in a synthetic baselayer:
  1. Use a patch or iron-on adhesive. If the hole in the synthetic baselayer is small, you may be able to cover it with a patch or iron-on adhesive. This can be done by cutting a piece of fabric or adhesive material that is slightly larger than the hole, and then applying it to the inside of the baselayer to cover the hole.
  2. Use a sewing kit or a needle and thread. If the hole in the synthetic baselayer is larger or more complex, you may need to sew it closed to fix it. To do this, you can use a sewing kit with a needle and thread that is designed for synthetic materials, or you can use a regular needle and thread and carefully sew the hole closed.
  3. Use a heat-sealing or bonding agent. If the hole in the synthetic baselayer is small and located in a seam or edge of the fabric, you may be able to use a heat-sealing or bonding agent to fix it. This can be done by applying the agent to the hole and then using a heat source, such as a hair dryer or iron, to seal the hole and prevent it from getting larger.
Overall, it may be possible to fix a hole in a synthetic baselayer, depending on the size and location of the hole and the type of synthetic material used in the baselayer. Try the methods above to fix the hole and extend the life of your baselayer.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sog Been 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 30
