跳转到主内容
苹果 2021 年的顶级智能手机。iPhone 13 Pro Max于9 月24日发布,配备6.7英寸ProMotion OLED显示屏、新的三颗后置摄像头系统和 5G连接。iPhone 12 Pro Max的继任者。
71 个问题 查看全部
Wifi, bluetooth, and cellular not working after drop
I recently dropped my iPhone 13 Pro Max, and as a result, it no longer connects to wifi, bluetooth, or cellular data. It also cannot send or receive texts or calls. I'm certain this is a hardware issue because it resulted from a drop, and I have tried all of the software troubleshooting methods available to no avail.
I want to know what kind of internal damage this could be. I haven't taken the phone apart because I want to know what my best option is, and it's possible that paying Apple an arm and a leg to replace it might be the better option. However, if it's easy/cheap enough to repair, I would be interested in doing that. My best guess is that the modem is damaged or disconnected, which I believe is an integral part of the motherboard. Is it possible to fix something like that? Is it possible a different component is damaged or disconnected that affects connectivity?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Since you have a couple of issues going on and the components that would cause your problems are located on the bottom layer of the board I think it would be safe to say that some of the solder pads that secure the top and bottom layer of the logic board have become cracked or torn off. There is not much you can do if you haven’t got the experience or the equipment to separate the two boards and inspect the solder pads.
The cost to repair your phone will depend on the damaged to the solder pads.
这个答案有帮助吗?
得分 5
添加一条评论
Today I dropped my phone and I am now facing the same problem. If you got it fixed can you please tell how you got it fixed and what was the solution?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Madison McClellan 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 54
过去 30 天: 277
总计 5,019
