跳转到主内容
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 个问题 查看全部
问题已关闭
Computer waking by itself while asleep.
My girlfriend's Macbook keeps on waking up on its own while it is asleep. This has been randomly happening while closed (without selecting sleep from the menu first) and while open (when sleep is selected from the menu). It usually happens several times in a row and then stops. Is there anyway to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
最有帮助的答案
A possibility: is your girlfriend using an Apple Remote Control for her iPod or her Apple TV? If so, this would interact with her computer as well. If that's a problem, Apple Menu --> Preferences --> Security --> Disable Apple Remote Control for this system.
这个答案有帮助吗?
得分 1
添加一条评论
Apples by default wake for Ethernet access. Disable this in the energy settings of your mac, sometimes a packet of info sent to the computer could cause it to wake on its own.
这个答案有帮助吗?
得分 1
3条评论:
this would only apply if the MacBook is physically connected to ethernet, this setting does not apply if just using wifi.
完成的
why was i voted down? it was never stated that the computer is not plugged in by ethernet...
完成的
We tried disconnecting her portable hard drive and ethernet and she doesn't have any bluetooth devices. Just moments after we put her computer to sleep, it tried to wake at least 6 times. I've also tried resetting the SMC, but moments after we closed it, it happened again. I just reset the PRAM and now we're waiting for the verdict on that one.
完成的
添加一条评论
The answers to this question should get you started. This is more likely a software problem than hardware.
这个答案有帮助吗?
得分 0
添加一条评论
Another thing to check - does she have a bluetooth device paired with the MacBook? Have seen this behavior with certain brands of bluetooth mice which send a burst of radio traffic when the mouse goes into sleep mode. This of course, then kicks the notebook into clamshell mode.
try turning off bluetooth on the MacBook, and testing if this resolves the issue.
这个答案有帮助吗?
得分 0
添加一条评论
Does it happen when logged in to a different account? When booted to an external or a CD?
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,298
