跳转到主内容
Repair guides and support for your Philips TV.
226 个问题 查看全部
Can I replace mainboard from a different model that shares the part?
Hello, my old Philips tv (40pft4100/12) recently developed a fault where it would turn on by itself and get stuck in a boot loop. I found that its most likely the mainboard at fault or the firmware getting bricked and the best possible solution is to replace the mainboard. I found some boards online to buy, but it seems to come from either 40PFK4200/12, 32PFH4101/88 or 40PFH4101/88. The part numbers and looks are identical, but since i'm no expert i am no sure if I can swap the boards from different model tvs. Would appreciate any help, thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yeah you can. I used the part from 40PFK4200/12 and it worked perfectly. As long as the part numbers are the same and the TVs have the same resolutions it should work. There was an extra input on the new board that the old one didn't have, but the TV chassis had a hole with a sticker on it where it was supposed to go.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vylius 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 130
