跳转到主内容
Repair information and disassembly guides for shop vacuums and wet-dry vacuums.
17 个问题 查看全部
Why is my Hyper Tough 1.5 gallon shop vac making a loud roaring noise
It's roaring like it is stopped up but it has some suction. I've done EVERYTHING. How can I take the top apart?? I've tried cleaning filter and all.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Hi
If you vacuum is making a loud “roaring” noise it’s probably one of two things
1)something is loose inside
Or
2)something is loose or had worn out in the motor
Here’s a disassembly guide
Shop-Vac MC150A Motor Replacement
If you go as far as the motor ,pay close attention to the motor bearings and where they are seated,if they have any play in them they are most likely your issue
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
添加一条评论
@charitymc08 have you removed the filter and checked the float? Post some good pictures of what that area looks like on your vacuum. Most tops on other shop-vacs are riveted whereas your model appears to have screws . Looks like you will need to remove those to remove the top.
After that I'd focus on screws 101 to remove the top toward the float etc. That is the area that I would focus on since debris there can create a blockage. We need to see more to try to help you further. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Charity Dianne Mclendon 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 53
过去 30 天: 143
总计 2,432
