跳转到主内容
The Ford Fiesta is a subcompact car (B-segment in Europe) manufactured by the Ford Motor Company since 1976.
16 个问题 查看全部
My ford fiesta 2008 doors won't unlock with my keys
So my car doors won't unlock using the keys but it does lock with the same key this problem used to be in the driver side only now the passenger door doesn't unlock too
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Did you get to the bottom of your fault? I have the same issue. Thanks
完成的
添加一条评论
1个答案
最有帮助的答案
Hi,
Check that the battery in the key fob is OK.
It may need replacing.
这个答案有帮助吗?
得分 1
2条评论:
You also might want to head to an auto parts store and pick up some graphite lock lubricant. In the old days this was just a tube of powdered graphite but nowadays it usually comes in a liquid carrier that can be squirted into the lock cylinder.
Either way, generously squirt some in and run the key in and out a few times to work it into the tumblers. This will help if your locks have gotten gummed up over time.
Also, if your key is double-sided, try flipping it over and see if that makes any difference. If the key is worn sufficiently it won't work correctly; in advanced cases you may need to go to the dealer or a locksmith and have them cut you a key using a key code rather than copying the existing key.
完成的
@dadibrokeit
It's getting harder to find new cars that have a lock in the door that the key can be inserted into to open it.
Earlier models had a key lock on both front doors but a lot these days only have it on the driver's side and now even that is getting rarer.
Once the key fob fails (for whatever reason) you're essentially locked out of your car.
完成的
添加一条评论
添加你的答案
bedoo150 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 108
总计 493
