LCD Screen Digitizer Interchangable between GSM and CDMA
Can the LCD screen and digitizer assembly interchangable between the AT&T version and Verizon model (GSM and CDMA)?
这是一个好问题吗?
取消
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店No, and yes. The difference is the attached thin mounting bracket that goes around the screen. The only difference being the 10 small tabs for the screws are in different places. So when you buy a new screen you definitely want to specify GSM or CDMA with iPhone 4.
声誉积分: 1
its not that hard. i had to do it because they sent me the wrong screen and i didnt realize it until it was too late into the procedure. I had to have my phone back so i switched the mounting brackets on my own and used superglue to attach it to the new screen. it worked fine.
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 8,052
