跳转到主内容
Guides and support for devices that play video from DVDs.
286 个问题 查看全部
Audiovox D1708 Portable DVD turns on but has blank white screen..
Hey there!
Turned on my D1708 and it shows only white screen&has no audio, everything seems normal other than that.. Power indicator works, when I put a disc in it'll try reading it, do you guys have any idea?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
When you say "...it'll try reading it,..." is the disc actually spinning or can you just hear the lens shuttle moving back and forth trying to read the disc?
If you're unsure, place the dvd disc in a remembered position in the player e.g. place it so the writing on the disc label is not upside down when looking at the disc and then start the player, allow it to try reading for a few seconds and the stop it and check the position of the disc.
If it hasn't moved it may be a drive motor problem.
If it has moved it may be a lens problem.
这个答案有帮助吗?
得分 1
1条评论:
It does move...
Is there a way to make sure it's the lens?
Might it be just in a need of cleaning or it needs replacement?
Specific way to clean it?
完成的
添加一条评论
添加你的答案
First Name 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 250
