跳转到主内容
加入维修社区 - 创建账户
第二代车型于 2002 年芝加哥车展上作为 2003 款车型首次亮相。该车型基于全新的 Impreza 平台打造,并针对前代车型进行了多项微调改进。
Went through a water crossing and now my car won’t start
So I went through a water crossing and got bogged, my car was starting at first just running a little rough, now it wont start at all but still cranks over fine, we tried tow starting it, it would go alright at first but I couldn’t actually accelerate at all, then when I stopped it would stop again.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
kiedis smits "water crossing and got bogged" how deep were you in? For now, I would not try to start it. Change all the fluids (Oil, gas, etc. Remove and change the spark plugs. Change all of your filters (Fuel/Oil/Air) and check your wiring. I particular, around all the fuse boxes under the hood. Check the bulk connector that connect the wires from under the hood to the inside cabin. Make sure you checked your ECU at all the rest of the sensors. Once you know that all the water/mud/etc. has been removed from your fuel system as well as your electrical system, try to get it started and address symptoms as they appear. You could try an OBD scan and see if that brings up any additional codes. Oh yes, make sure you have no water inside the catalysator and the muffler.
这个答案有帮助吗?
得分 3
1条评论:
Also, pull the spark plugs and crank the engine over for a bit to blow all the water out of the cylinders. Learned that one through experience.
由完成的
添加一条评论
添加你的答案
kiedis smits 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 27
总计 630
