跳转到主内容
Repair guides and support for your Philips TV.
220 个问题 查看全部
Philips 42PFL7422D/37 The TV only works if I manually press the relay
So, how do  I troubleshoot this?  The TV only works if I manually press  the relay on the power supply board, after I do that it will stay energized.  It appears to not be  getting some kind of control voltage to energize it and keep it energized so the power   required to operate the TV can get to the rest of the TV from the PS board.
I noticed that there is no 5v (standby?) voltage constantly at the relay even when the  TV is off (I think it's supposed to be there ?)
Sometimes after pressing this relay it will not stay energized, in this condition, I was able to  measure  5 v across the relay which indicates  that   the other side of the relay is not allowing current to flow through it.
I' m thinking there is something in the standby circuitry that may be the culprit?
Philips TV  Model  42PFL7422D/37  SN: YA1B0729020266
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Here are some images of the standby voltage circuit from the service manual that may help.
(click on image)
Hopefully a start
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
H B 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 25
