跳转到主内容
Clothes dryer repair and support guides.
870 个问题 查看全部
My dryer isn't turning the clothes bin
My dryer was working fine yesterday but today itwas hard for it to move a little weight.but when i turn it for a little with my hand then it is working fine my dryers model is INDESIT IDC75 . That's the oink to the video https://drive.google.com/file/d/17rY6oQO...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Vagelis,
This sounds like you have a bad starting capacitor. When they fail, the show symptoms just like this. The capacitor is located in close proximity to the motor inside, so (if you’re comfortable with a little DIY) you can open the dryer and inspect. Here is a link to the instruction manual for the model you specified.
If you take some good quality and up close pictures of the insides, and then update the question following this guide Adding images to existing questions we can see what it looks like.
Your model should use a 8.5uF(microfarad) capacitor. Here is a link to one, that also shows what it looks like.
这个答案有帮助吗?
得分 3
3条评论:
Thank you so much I will write again when i have fixed it
完成的
Thank you so much i replaced that and it worked
完成的
@Vagelis Awesome! One more saved from the ever after.
When any electrical motor won’t start on it’s own, but will start if you give it a gentle push, 99 times of a 100 it’s a faulty starting capacitor.
完成的
添加一条评论
添加你的答案
Vagelis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 33
