跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
20 个问题 查看全部
My console wont turn on with a new battery.
Hi, I recently bought a broken 3ds from ebay for $30 USD, without the SD card. The console won't turn on, and had some rust that I fixed with some WD-40. It looks and feels brand new, is the unit bricked? I have seen things about the black screen of death but I was going to go here before I made any moves. Here is the link to the pictures: https://imgur.com/gallery/3Q2qbxT Thank you in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Monke Monke "had some rust that I fixed " where? Which area? what does the bottom of the board look like?
完成的
@oldturkey03 it had some rust with in the top screen and by the gamecard slot
update it was water damage, real bad rust at the bottom of the board
完成的
添加一条评论
2个答案
If you are noticing rust or corrosion on your logic board, I would suggest cleaning it with Isopropyl Alcohol, continue cleaning until all corrosion is removed, give it a few minutes to dry, then begin reassembling the unit, then attempt to power it on
这个答案有帮助吗?
得分 0
添加一条评论
@Monke Monke looks like your board got some issues. Hence the importance of always removing the board and checking both sides. Okay, time to clean it. Use something like this guide , and even so it was written for an apple iPhone 3G, all the points are still pertinent to your 3DS.
Once properly cleaned, check the components for obvious damage. Check the individual traces to make sure they are not torn or have lifted. Check F1 and F2 for continuity. Do not try to power it up etc. until it is cleaned. It could further damage your board. If you are really ambitious, you can check the test points after it has been been cleaned. this can help for further troubleshooting TP Testpoints For 3DS
No more WD40 since it can create more trouble as a conductor.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Monke Monke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 110
