跳转到主内容
17 inch Laptop, i3 Intel Processor, Built-In Battery HP Product number 37P29UA
2 个问题 查看全部
Power light is on but nothing turns on
When I press the power button the charger port blinks 3 times! I have disconnected the battery, ram, and hdd and nothing happens. The charger light won’t light up when plugged in with or without battery! I don’t know what else to do. Caps lock light is always on as well.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
ItzBabin try this first
  • Power off the laptop.
  • Your laptops battery is "integrated" so don't do anything with that.
  • Disconnected AC adapter from the laptop.
  • Press and hold the power button for 15 seconds.
  • Reconnect the battery and plug the AC adapter. Try connecting the charger to a good known wall outlet.
  • See if you can Power ON the laptop.
It does sound like your AC Adapter could be the issue here. Let's start with that. Check the power cord to the charger with a meter for continuity. They do like to fail. Check the output of your AC adapter by inserting the red probe into the barrel connector and the black probe on the outside. your meter should be set to DC voltage and show something like 19.5V. LEt us know what you find out.
这个答案有帮助吗?
得分 1
5条评论:
I have done those steps when I had to take it apart the first time an nothing still happened!
完成的
@ItzBabin did you physically check your AC adapter? There are common issues with the power cable
完成的
Yeah I did, nothing wrong wrong with it. I disconnected the ram hdd an the battery, an did all those steps you said
完成的
@ItzBabin Yes, I wasn't to concerned about the steps since I already figured you may have done those. They are pretty common first steps. My concern is first and foremost with the power cord. I hate for you to tear down your computer to get to the power rails on your motherboard and having to check all of those. I guess that would be the next step.
完成的
I have one on order right now, should be coming in today because that’s what I’m thinking too! I will definitely let you know if it was the power cord or not!
完成的
添加一条评论
添加你的答案
ItzBabin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 117
