跳转到主内容
蘋果2020年的主流型號iPhone,其發布於10月23日,搭載6.1吋OLED螢幕及12MP雙鏡頭模組。其有著5種顏色,為iPhone11的後繼產品。
165 个问题 查看全部
PH #00 or JCIS #00 Scews
To begin this is mainly about the screws that need to removed in order to change out the camera but it does apply across the board.
In iFixIt guides they call for the 00 Philips screw driver but in Apple's own self service guides and tool purchases/rentals it says JCIS bit. I know the differences between PH and JCIS is very minimal but it still seems somewhat important to know the difference.
So basically, regardless of how much it may or may not matter, which is the actual 100% correct tool? Does apple use JCIS screws instead of Philips or???
Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi
This is a hard one,while apple says it is a jcis screw a Philips driver will work along side a jcis driver
So really it’s 6 and two 3s(the same thing with a slight difference)
Let’s just say for now that they are both correct as they both do the job and tick the boxes
Just as a example:A LCD tv makes a picture and so does a LED tv ,they are the same but ever so slightly different but roughly use the same process of getting what they are intended for
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ryan Southern 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 20
总计 96
