跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
Home button doesn't work after logic board replacement
Hey there! I recently swapped out the logic board of my iPhone 8 plus, however the home button no longer functions. I knew going into this, touch id would be disabled. I never used it, so it wasn't a huge tradeoff for me. However, the home button is now completely unresponsive. One time when I turned the device on, it did say that the home button may need serviced. Would replacing the logic board completely break the home button? It doesn't look like there is any physical damage to it or the flex cable at all. Ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yeah, unless you swapped over the original button from the old phone, that button isn't going to work. Starting with the iPhone 7, the button isn't mechanical any longer; it's now a capacitive sensor which is tied to the Touch ID software key. As a result, neither the Touch ID nor the home button function will work when you replace the home button.
The repair industry has come up with a solution though; they make a 'universal' home button that converts it back to mechanical action, allowing it to work as a home button - no Touch ID, of course, but at least it will still click. Early versions actually connected via bluetooth of all things; you don't want one of those.
So in order to fix your problem you'll have to go buy an aftermarket universal style button. iFixit sells them; it appears the iPhone 7, 8 and plus variants all take the same button, so all you have to do is pick which color you want.
iPhone 7/7 Plus/8/8 Plus Home Button: Assembly Replacement
Good luck; let us know how it goes!
Replace a home button compatible with the iPhone 7, iPhone 7 Plus, iPhone 8, iPhone 8 Plus, and iPhone SE 2020.图片
产品
iPhone 7/8/SE 2020 Replacement Home Button
$23.99
这个答案有帮助吗?
得分 1
2条评论:
Will buy! To confirm - clicking the button will go home, right?
完成的
Yep, that's the whole point. Glad I could help!
完成的
添加一条评论
添加你的答案
blockarchitech 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 212
