跳转到主内容
Repair guides and support for your Philips TV.
226 个问题 查看全部
I can seen even very dark image
Hi guys,
I have the same problem.
Mine TV (QM16.3E LA - 49PUS6551/120 ) gave up yesterday, after almost 4 years. Screen went black all of the sudden, I tried all kind of resets, power drain but still is black.
All other works, sound, ambilight, I can seen even very dark image - UI of Android so I believe it can be only defective backlight, or?
Any chance to verify that LED strips are failed only? I've seen a videos how to change them, but I would like to rule out T-Con board, or power supply. I am going through the service manual but still not sure where I could measure voltage on PSU or T-Con to test if LED strips are getting power. I don't want to do such work before knowing it is the root cause :(
Any idea please?
Video - chaning LED strips
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@marcmsk the chance are pretty high that it is the backlight array. Philips has some issues with those due to subpar quality. Anyhow, "I believe it can be only defective backlight" there is always a chance it could be the power board not supplying adequate power to the lights. Check your power board and measure the voltages going from the connectors on the power board to the LCD strips. It is DC voltage, so set your meter accordingly and start high then go lower on the settings. There are also inexpensive LCD backlight testers to be had at Amazon, Walmart etc. If you purchase one of those, you can quickly verify, if it is the backlights that have failed.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 24
