跳转到主内容
Mid 2013 revision to the Xbox 360 line of game consoles, featuring 4 USB ports and built-in Wi-Fi connectivity.
90 个问题 查看全部
What steps should I take to check why my fan isn't working?
I have been dealing with the insufficient ventilation error, and noticed that the fan was not spinning at all. I did some testing and was able to confirm that the fan works when using an independent power source (9V) battery, but I would like a permanent solution to fix the power to fan issue. When I removed the motherboard I did find that there was some water damage (got this from facebook) and it was over the whole board. I have no idea what I should be checking to narrow down what would cause the issue, is there a diagram that can show me what on the board is related to powering the fan?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I found these schematics on Google if it helps:
https://archive.org/details/Xbox_360_Xen...
Water damage can be very tricky. It wouldn't be a terrible idea to start by giving the motherboard a good cleaning, especially if everything else is working. Take plenty of pictures before doing so. Sometimes cleaning the board is a fix, but if it's not, having those pictures is a good reference point to troubleshoot further.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Doxx 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 73
