跳转到主内容
Windows 11 has an all-new user interface including a new taskbar, new centered icons, window transparency, rounded corners, and a refreshed Microsoft Store.
4 个问题 查看全部
22h2 update not showing on brand new laptop.
The windows 11 22h2 won't show anymore on my brand new Acer laptop after some driver updates and can't find what driver it is or how to uninstall it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @fpfp
Here's a link that may help
这个答案有帮助吗?
得分 1
5条评论:
Already tried most of them and didn't work.
完成的
@fpfp
Try the following:
Start the laptop and when it starts to boot into Windows, force stop it by holding the Power button operated until it shuts down.
Do this 3 times in a row i.e. Start > boot > force shut down > start > boot > force shut down > start > boot etc.
On the 3rd attempt it should boot into the Windows Recovery menus.
When there click on Troubleshoot > Advanced > Startup repair and follow the prompts.
Do not select "Reset this PC" because if you select the wrong option after this you can delete all your data as Windows will be reinstalled.
Once (and if) you get it working etc check that you have a restore point set. This way you can restore the PC to an earlier point in time a lot easier. Go to Control Panel > Recovery > Configure System restore and configure it for the C:\ drive as usually this is te Windows OS drive.
完成的
@jayeff I don't have any restore points as i just got it.
完成的
@fpfp
Once you get it working correctly activate the restore point and also make a recovery USB Go to Control panel > Recovery.
Both are very helpful if you need to fix a PC
完成的
@jayeff I just manually installed it instead.
完成的
添加一条评论
添加你的答案
fover 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 93
