跳转到主内容
互联网电子眼、智能家庭监控以及WiFi连接摄像头的维修和支持指南。
135 个问题 查看全部
How to connect to this camera (not a d-link)
Hello,
I got hands on this device, and I am unable to figure out how to work it.
Scanning the QR code just search for the device ID on google without results.
When I plug it in to my computer, it beeps every minute, but I cannot find anything connected, not with bluetooth or wifi.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Jonah Madeya try to post a clear picture of the bottom label. I am old and have trouble seeing it even when zoomed in. I wonder if it uses the USB just for charging and not for any kind of data, Tried some generic drivers. Check on sites like this https://www.ispyconnect.com/camera/gener... or http://yatundev.eu/drivers/generic-fixed...
完成的
Smart Camera
DC:5V/3-5W
WI-FI:2.4G 802.11b/n/g
This what was under, sorry it's hard get a clear picture of it. I think you might be right about the USB being simply for charging.
Also forgot to mention it has an enclosure for an SD card.
完成的
添加一条评论
1个答案
最有帮助的答案
@Jonah Madeya
Does it have is own power adapter attached to the USB cable or is it plugged into a USB 2.0 port on the PC?
Just wondering if it is plugged into the PC whether there's enough power to fully operate the device.
The specs underneath show 5V 3-5W so this means it requires a current flow of 600-1000mA. Usually USB 2.0 ports in a PC supply only 5V @ 500mA, i.e. 2.5W
If you have a charger with a compatible USB plug (mobile phone charger?) that supplies 5V @ 1A (or even 2A - the device will only take what it needs) try using that to see if you can detect the WiFi signal (specs show 2.4GHz 802.11 b/n/g)
Also insert a formatted SD card as well. I've read that the camera on some drones doesn't work without a card inserted. Maybe this is the same.
这个答案有帮助吗?
得分 1
1条评论:
@jayeff I was considering it, to have an external power supply to provide the proper current.
完成的
添加一条评论
添加你的答案
Jonah Madeya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 49
