跳转到主内容
Repair guides and support for your Panasonic microwave.
8 个问题 查看全部
model NN-SN966S Lost all control of the keypad exept Reset
First, out of the blue, the display screen showed the Power Level counting down repeatedly (P 10, P 9...) while at the same time the speaker was sending out a continuous beep, beep, beep.
When I unplugged the device for a couple minutes, then plugged the power cable back into the socket, the display came up flashing and showed 88:88. I pressed every button on the keypad and only the Reset button worked clearing the display and showed : and again none of the keys on the keypad worked.
Anyone have any ideas? I'm thinking maybe the keypad failed or possibly the microprocessor. Is this even fixable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
Did you find an answer. I have the exact same problem.
完成的
I, too, have this problem. Pressing Reset causes a beep and clears the 88:88 from the display. No other buttons beep or do anything.
完成的
Hi, I am having the same issue. Did you find a solution or just have to purchase a new microwave? Thanks!
完成的
I m having same issue
完成的
添加一条评论
3个答案
最有帮助的答案
Same issue ...I got a new microwave and a couple weeks later plugged it back up just to see and it worked... worked for day and half then did it again.
这个答案有帮助吗?
得分 1
2条评论:
Hi @dustinjarrett,
If it is "new" check the warranty provisions for the oven that are usually found in the user guide that came with the oven, as to what to do to make a claim for a manufacturer's warranty repair, replacement or refund.
That's what warranties are for.
完成的
From what I've been reading they are saying it's a faulty door switch. I'm going to check my door switch to see if that fixes the problem. This is my second microwave doing the same exact thing so might be able to fix both cheap.
完成的
添加一条评论
@flasharoo since there are no schematics for the keypads, it might be difficult to repair those. From what you are telling us, it sounds like a bad keypad. Of course, check it for any obviously failed component and post pictures. That way we might identify what may have gone wrong. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
Yes, Panasonic is aware of this faulty product, and has a solution. A chat with tech support today (9-12-2023) said "Yeah, those are symptoms of an internal component failing, unfortunately. Would you like me to look for a service center?"
My microwave, and dozens of other people's (read the unhappy 1 star reviews on Amazon) echo the exact same failure sequence. And they are not happy, because if it is out of the 1 year warranty-- so it's toast. For what I paid (over $350 with tax and shipping) it should have lived longer than 2 years and 6 months!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harry Childs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 41
过去 30 天: 196
总计 924
