跳转到主内容
The Sega CD model 2 was a revised model of the Sega CD released in 1993 to accompany the updated design of the Sega Genesis II.
4 个问题 查看全部
Weird thumping sound and disc read error after cap replacement
I just replaced the caps in my sega cd model 2 because it looked like a few had leaked, it was working fine before but wanted to do it now before it got worse, now it has a weird audio glitch and it won’t read discs
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
12条评论
@cwr81 which capacitors did you replace? Post some good pictures of your work. Did you double check your work and your reassembly to make sure all is where it is supposed to be?
完成的
@oldturkey03 I added the pictures, I replaced all of the capacitors, I made the mistake of not testing after each cap but I did do them one by one to make sure I had the polarity correct.
完成的
@cwr81 that looks neat. One more thing and I know it's a pain but take a good closely zoomed picture of the boards bottom side. I am thinking solder bridge etc. Let's see...
完成的
I have added the pictures now of the bottom side
完成的
@oldturkey03 I have also tried another Genesis just to rule that out and still had the same effect so maybe I messed up a capacitor but I don’t know for sure
完成的
显示更多的7条评论
添加一条评论
1个答案
最有帮助的答案
@cwr81 I'm posting this as an answer, as that is the only way I can attach images back.
I have marked a few suspect areas with red, both with squares as circles.
You can see close up that there are some places where the excess solder overlaps other traces and (although it should be safe-ish) it's not a good practice as it can cause hard-to-find problems.
这个答案有帮助吗?
得分 2
9条评论:
I have gone through and reflowed anything that looked suspicious but still getting the same result unfortunately
完成的
Ok so now I don’t know what I did but it suddenly is reading discs
完成的
@geirandersen I got the games to play but the sound is still messed up
完成的
@cwr81 since this started to work. Keep on redoing your caps. I know you are capable but some of those may not make proper contact or have a bit of a bridge. Take a good look at all of them. You would not be the first one that may reverse a cap or has a solder bridge :-)
完成的
I think a chip might be fried now, I’m having real bad video glitching and audio glitching, I’ve already spent too much time on this already so I may just use it for parts
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Nascar1243 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 338
