跳转到主内容
The Sony Betamovie with model number BMC - 220 was released in 1984. The camera is part of the second generation of the Betamovie line and was one of the first camcorders marketed to average consumers.
4 个问题 查看全部
What kind of battery is used?
I just bought a beta movie BMC-220 and it didn’t come with a battery. I don’t know much about batteries, but with some research, the closest answer I’ve gotten is a NP-11 battery. That’s a rechargeable battery and I’ve seen lots of NP-22 and -55, but not very many -11s. Are they interchangeable? And do they all recharge from the same charger? Do all rechargeable batteries recharge with the same charger? What is the rechargeable battery/charger ratio? Is the NP-11 even the right battery for a BMC-220? I know this is a lot of questions, but let me know if you can answer any of them. Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Sheridan Richmond darn I remember having paid a fortune when they first came out. It was like a month pay :-)) Great guide right here. Anyhow, the BMC-220 uses a AC-M110 AC adapter/charging unit and the NP-11 as batteries. The NP-11 was a Nickel-Cadmium 9.6V 1000mAh battery. I don't see to many NP-11 out there but they can be rebuild. If you are into vintage electronic, might as well get used to doing that as well. Check on here for a rebuild. Of course you can always try and adapt a "modern" RC battery to that. Lots of them out there with proper chargers and all but you may have to modify the power adapter on the Betamovie.
Anyhow if you get stuck with anything or need more input, post some good pictures of what's going on with your camera and power supply, with your QUESTION. 在已经存在的问题里加入图片
No
No
Due to the difference in physical and electrical dimensions the charger must suit the battery.
No. Same reason as before.
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
Sony Betamovie BMC-220 Battery图片
指南
Sony Betamovie BMC-220 Battery Replacement
难度:
中等
3 minutes
这个答案有帮助吗?
得分 2
3条评论:
Thank you so much for this answer! This information has helped so much, you have no idea.
I have a follow-up question. I am curious about the AC-M110 AC adapter/charging unit. Is that adapter a charger for the camera itself? Or for the battery? If the adapter charges the camera and not the battery, does the Betamovie need a battery if it has the adapter? What are the relationships between the adapter, camera, and battery?
完成的
@Sheridan Richmond that is the adapter that charges your battery and can provide power to the camera. It will not charge the camera (nothing there to be charged other than the battery) but it will provide power to the camera for as long as it is plugged in. Hope this make sense.
完成的
Yes, that does make sense, thank you! I'm literally so grateful, I appreciate it so much.
完成的
添加一条评论
I have this issue with almost every old camera I'm asked to use. I have found a helpful work around that doesn't cost the earth AND is easy to do.
the easiest way that I have found to sub in batteries for old tech is by ripping out the old cells and replacing with a modern eqivalent. The Sony beta cam power cell NP-11 outputs 9.6v at a draw of 6.2w; So, a RC battery that you can get from Amazon for 20 bucks or so would fit the bill.
https://www.amazon.ca/Melasta-2000mAh-Ba...
Crack open the power pack caeefully remove the old cells, solder a male jack to the battery header on the inside - drop in your new powercell connect the jacks and tape the battery enclosure closed. Pop it in the camera.
Just don't use the old charger to charge it!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sheridan Richmond 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 335
