跳转到主内容
The dual SIM version of Nokia's C2 series, released in 2011.
9 个问题 查看全部
My nokia c2 01 is hard to power up
So my nokia c2 01 is hard to power up because the processor might be damaged, is there a fix for it?
Update (10/14/23)
After a year I found the solution it probably has low menory that's probably why,it worked after I put in a sd card
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Pawel C what do you mean by "hard to power up" and why do you think the "processor might be damaged"? What have you tried to fix it? What have you checked? Have you replaced the battery?
完成的
@oldturkey03 It's like I was playing the tour of diamond rush and when level 1 finished loading my phone restarted, there was a white screen and then nothing and I remember there was an other battery that didn't charge but I had a BL-5C battery from another nokia and I put it in the c2 01 and it started automatically and a couple days later it was hard to start it up I even tried charging the battery with the other Nokia and when it was full I put it in the c2 01 and then nothing I tried to power it on but it didn't, I haven't checked anything yet and why I think the processor is damaged:The answer is simple, it's hard to power it on and from the story I did replace the battery I think
完成的
After a year I found the solution it probably has low menory that's probably why,it worked after I put on a sd card
完成的
添加一条评论
1个答案
最有帮助的答案
Hi,
Here's the service manual for the phone.
Phone Nokia C2-01 RM-721, RM-722 - Service Manual. Level 1 & 2. Version: 1.0 shows dis-assembly etc.
Phone Nokia C2-01 RM-721, RM-722 - Service Manual. Level 3 & 4. Version: 1.0. has the troubleshooting flowcharts
Phone Nokia C2-01 RM-721, RM-722 - Schematics. Version: 1.0. has the schematics and the board layout.
Hopefully using these will help you to find the problem
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Pawel C 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 173
