跳转到主内容
沃克斯豪尔汽车的修理和支持指南。 成立于1903年的英国汽车品牌。
63 个问题 查看全部
Corsa VxR repair manual
Dead cylinder 4 unsure why. Rough idle running, zero compression in one cylinder and low in the rest (8 bar)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@hamzamsj this "zero compression in one cylinder and low in the rest (8 bar)" needs some serious work. You do need theck your valvetrain and your Pistons, head gasket etc. as well as multipole other things. Do a leak-down test and see what that reveals. A compression of zero will cause all the other symptoms you are referring to. Anyhow, I am certain a manual will be available but you need to let us know what exact year and engine size your VXR is.
这个答案有帮助吗?
得分 0
2条评论:
It’s a 2013 VXR Nurburgring edition. It’s turbocharged and has a A16LER engine which has a relatively low mileage at 74k
完成的
It’s a 1.6L manual engine
完成的
添加一条评论
添加你的答案
Hamza Mumtaz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 163
