Frigidaire Dryer Model#gler341as2 Noise After Heating Up
My dryer starts quiet and normal and drys clothes fine. However, after only a few minutes of being on, it starts humming loudly. I have taken everything apart and cleaned thoroughly including blower fan, motor, and exhaust. Any and all lint and debris has been cleaned. I've inspected rollers and all the other aspects of the dryer that the internet tells me is the cause to a noisy dryer. Everything seems to look good, but after reassembling the problem persists.
Loud humming after a few minutes of being on. I have a suspicion it's the element, but how does the element cause a loud humming noise like that?
Thanks in advance!
4条评论
Is it a humming noise or a buzzing noise?
由 mayer 完成的
Starts off humming, then as it gets louder starts sounding more buzz like.
I did notice the tension spring for the belt was vibrating against the motor. I was able to alleviate that which helped quiet things down, but there is still a good noise coming from it... It seems to get louder and louder the hotter it gets.
由 Daniel Swirzewski 完成的
Hi Daniel,
Another few questions, you have indicated that the noise sounds like it is coming from the heating element.
Does the dryer ever shut off mid-cycle, or does it go all the way to the end of the cycle?
Also if you do one load, take it out of the dryer immediately and do another right away, does the hum start immediately or does it still take the same time to build up?
Does it hum on any cycle, or only on cycles with heat?
Does the hum go away near the end of a cycle sometimes?
When you took things apart, did you remove the dryer drum?
由 Bill Gilbert 完成的
-The dryer does NOT shut off mid-way.
-If I start the dryer after doing one load and start another without letting the dryer cool, the noise is immediately there.
(When the dryer has been off a while, it starts quiet and builds up)
-It doesn't seem to hum that loud on AIR FLUFF/NO HEAT.
-I don't notice the noise getting lower when ending a cycle.
-I did take the drum all the way out. The element looked old but I'm not sure what to look for otherwise.
Thanks for helping out, Bill!
