跳转到主内容
After switching on device all three temperature indicators started bli
After switching on device it heats up while and all the temperature indicators started blinking.
Still straightener keeps on heating, but temperature level couldn't be identified as all three indicators are blinking
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Your Steampod flashes due to a component failure. In the majority of cases, it will be a failure from one of these elements:
  • the resistance of the plates
  • the electronic card
  • the thermostat
  • Before moving on to hardware repairs, remember to check that there is enough water in the tank flashing Steampod straightener. Indeed, if it lacks water, it may not be able to reach the requested temperature and therefore it signals you by flashing. Also check that the hair straightener is not in energy saving mode. Indeed, the device goes into standby after 1 hour without manipulation. If you try to turn it on without having reset it, then it may start blinking and not turn on. To reset the Steampod, you just have to long press the on/off button.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Muhammadbilal Pathan 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 25
过去 30 天: 98
总计 788
