跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 个问题 查看全部
MacBook Pro 6,2 won't run off of a fully charged replacement battery.
I replaced the battery in my 2010 UNibody 15" Macbook pro. The replacement battery has fully charged, but the computer won't fun off of the battery.
When it's plugged in, the batter indicator lights as well as apps like Battery Monitor show a full charge and perfect battery health. However, as soon as I unplug the power cable, the computer shuts down, just as if i didn't have a battery in the machine.
I've tried both an SMC reset as well as a PRAM reset. No joy - any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sadly, your systems power logic on the main logic board is having problems switching between the two power sources. One of the MOSFETs has failed and will need to be replaced. This often happens in this series.
Time to find someone with good micro soldering skills to fix your logic board.
这个答案有帮助吗?
得分 2
2条评论:
So, i guess i'm basically looking at a motherboard replacement? So, even though it was able to CHARGE my battery, it's unable to USE the power from the battery?
完成的
No, you need to get your logic board fixed, not replaced.
完成的
添加一条评论
添加你的答案
David Kim 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 13
总计 43
