跳转到主内容
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
89 个问题 查看全部
PSP go wont turn on.
I recently got a PSP go. I've had it for a week and not dropped it once, infact i've babied the thing because it's so thin and light i was worried i'd break it(go figure). It fell out of my pocket when i was kneeling and hit a hardwood floor and landed on a blanket afterward. after picking it up and checking for cracks i tried to turn it on and nothing happened. i plugged it in and the charging light came on for a second then went off, and it still wont turn on. Any ideas what messed up and if it's fixable? I think it might be the battery coming loose although without any jewelers screw drivers to take it apart yet with.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
You've got the right idea Vince. The battery would be the best place to start and is a likely culprit for your issues. See if you can get your hands on a plastic opening tool and Phillips #00 screw driver and use this guide to help you get into your PSP. Good luck and let us know what you find.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vince 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,570
