跳转到主内容
这台13寸的MacBook Pro使用四核英特尔十代i5/i7处理器和锐炬Plus核芯显卡,于2020年5月发布(型号为A2251/EMC3348,拥有4个雷雳3接口)
69 个问题 查看全部
MacBook erased, but won't boot after xartutil --erase-all comm
After erasing the MacBook, I also wanted to erase the Touch Bar. However, after the command
xartutil -erase-all
My MacBook does not start anymore. The screen no longer lights up or turns on. Tried all reset commands. How do I get him to work again?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You'll need access to another TB Mack system to run the Apple Configurator 2 app to try to re-install the system firmware. Here's more on it How to install Apple Configurator 2 for macOS
Basically, putting the system into DFU mode
Try running both Revive and Restore options
这个答案有帮助吗?
得分 2
4条评论:
Thanks for the answer. When i erased the macbook it worked fine. but after the command xartutil-erase it is complete dead and i also get i not in DFU mode. is ther another solution maybe....?
完成的
@maxgeertsen - Your system uses firmware which is stored on the drive which you erased! What made sense in older systems creates issues with the newer models.
The other option is visiting an Apple Store who have a tech that can reload the firmware partition.
完成的
Hello, I also deleted the touch bar and I have the same problem as Max@geertsen.nl, did anyone manage to restart their macbook after turning it off? Thanks
完成的
@rorovd83 - As I explained you need a second system to run the Apple Configurator 2 tool.
完成的
添加一条评论
添加你的答案
Max@geertsen.nl 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 10
过去 30 天: 58
总计 770
