跳转到主内容
加入维修社区 - 创建账户
Xbox Series S是微软于2020年11月10日发布的轻巧纯数字游戏主机,与Series X属于同世代产品。本页面包含 Xbox Series S的维修指南、拆解信息,以及疑难解答。
Why is the Xbox Series S power light flicker and then turning off?
I'm trying to repair an Xbox Series S. When I try to turn on the console, the power light turns on for a second, and then shuts off. Other than that, the console does show any visible response to pressing the power button. The fan doesn't even attempt to start spinning up. I've tried booting the console in safe mode, but it gives the same result. At first, I thought that it might be a power supply issue, but replacing the power supply didn't do anything to fix it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
最有帮助的答案
It could be a safeguard built in by Xbox that occurs if something is broken or damaged internally. Have you tried looking around the motherboard for loose connectors? If you haven't then please try it. If this doesn't work, try a different outlet or try a new power cable.
这个答案有帮助吗?
得分 1
3条评论:
I've tried reseating all of the connectors, and it didn't make a difference. I've also tried it with different cables and outlets.
完成的
Do you have a spare working power supply? If you do then try to use that. If it still doesn't work then its a motherboard issue.
完成的
I have this same issue. There was water damage on the motherboard...I cleaned the corrosion with 99% rubbing alcohol and replaced the power supply (I couldn't figure out how to open the power supply to clean). It worked! I even saw the accounts from the og user i bought it from and was able to factory reset it. I was installing games overnight to play the next day...In the morning found the console off and figured it went to sleep after the install, but the issue came back! It turns on for a sec, then makes a sound and immediately shuts off. I haven't wanted to open it up since then...
完成的
添加一条评论
You can try removing the SSD and powering it. If the console starts, that means the problem is from the SSD. I have the same issue trying to find a solution. Not even a technician could fix it. Said bad SSD and returned it. I suppose there is problem that is causing shortage somewhere in the motherboard. Sadly, I cannot find the source since the motherboard looks perfect.
这个答案有帮助吗?
得分 0
1条评论:
Did you ever find the answer?
完成的
添加一条评论
添加你的答案
Jane Cameron 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 51
过去 30 天: 199
总计 6,218
