跳转到主内容
加入维修社区 - 创建账户
Xbox Series S是微软于2020年11月10日发布的轻巧纯数字游戏主机,与Series X属于同世代产品。本页面包含 Xbox Series S的维修指南、拆解信息,以及疑难解答。
Xbox Series S keeps shutting off
My Xbox series s keeps turning off at random moments. It can be after an hour of gaming, or literally 2 seconds after I turn it on. I’ve tried plugging it into different outlets, factory resetting, leaving it unplugged for an hour, still no luck. Not sure if I should buy another power cord, but it doesn’t look physically damaged. Not sure what I should do at this point. Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
6条评论:
Cheapest and easiest thing to do is a power cord. I would try that first.
完成的
Very good point
完成的
Thanks for the suggestion. I have one being delivered today. I'll provide an update as to whether the issue continues or not.
完成的
Good luck. Hope it works
完成的
Yea, the cord wasn’t the issue. The only thing I can think of before getting it repaired/getting another Xbox is trying a cooling fan? The Xbox doesn’t feel hot but maybe it’s overheating.
完成的
显示更多的1条评论
添加一条评论
2个答案
It could be a power cord issue, but it could also be the power supply that you need to replace. It could also be the motherboard, which I doubt. If you decide to get a new power supply, be careful with the broken one. Do not open the old power supply. Does your Xbox have good ventilation? Here's the article from xbox.com
https://support.xbox.com/en-US/help/hard...
这个答案有帮助吗?
得分 0
8条评论:
I came across something that I've only been able to test for one day, but I think it may have fixed my issue. My video display was set to automatic. Once I switched it to manual (HDMI), I was able to change my Xbox from 120Hz to 60Hz. Although the picture seems wide beyond the borders of my tv, I haven't had any more issues with the Xbox shutting off.
I'm not sure exactly how this fixed the issue, but it's been working ever since.
完成的
@gssiler7 That's good. well hope you find out how you fixed it.
完成的
It turns out that the issues still persist. I'm getting a diagnostics test run on it today. Just debating on if I'll pay a bunch of money for someone to fix it, or order parts and fix the issue myself.
完成的
Do you get a overheating message before it shuts off?
完成的
No. I’ve never gotten that message. I took it to ubreakifix and they’ll have some answers by Thursday. He said it could be the fan, power supply, or motherboard (if the motherboard, there’s nothing that they can do about it).
完成的
显示更多的3条评论
添加一条评论
It just overhead nd the fan will turn on all way up
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gavante 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 33
过去 30 天: 95
总计 5,842
