跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
309 个问题 查看全部
Won’t complete bootup
2009 21.5 iMac. After a very brief power fluctuation (sudden power loss , 3 second outage and the power came back) I attempted to turn my iMac back on. The iMac will chime, the Apple logo will appear and the progress bar will go across the screen until the veery end and then the computer will just stop. I have reset the PRAM and was able to boot into the disk utility and perform a a disk repair. but the iMac still shows the same issue. I am stumped. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Sounds like a possible RAM problem or a dying HDD. Did the iMac say the HDD was successfully repaired? First point of call should definitely be trying some different RAM.
这个答案有帮助吗?
得分 0
添加一条评论
The iMac did say it was successfully repaired. I did remove some of the RAM but the same problems occurred
这个答案有帮助吗?
得分 0
添加一条评论
I removed all of the RAM, added one of the RAM by itself into the iMac and then performed a boot up. No change… the iMac boots up , the startup bong hits and the progress bar starts up and then …nothing. The progress bar just stops. I did this with each of the existing RAM sticks of this iMac. I even tried some extra RAM modules that I had stored away but the same results occur
I’m confused as I am able to get into the disk utility and I’m told that the disk drive is fine. Is it a hardware or software issue ? Would a reinstall of Mac OS X solve this boot issue?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mark Pearson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 59
