跳转到主内容
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
156 个问题 查看全部
battery connection port on the motherboard?
Can someone please tell me the proper way to replace the battery connection port that is soldered onto the motherboard. I have a donor motherboard with a good port and I need to replace it on my AGS – 101.
Update (09/26/2022)
Here is the image
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi
I would remove it by applying low metal solder to the visible pins on the board then remove it using a hot air rework station to avoid melting the plastic on opposite side of the board to the connector
That’s the way I remove delicate connectors when I’m soldering
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
2条评论:
My only issue is I don’t have a hot air rework station. I was going to try to heat up the mounting points with my small tip on my iron and try to pull it off that way but I don’t want to damage the board.
完成的
@biggriff
The hot air is the safest way but you could try this stuff called chip quick which melts at REALLY low temperatures
You could try it but you will have to be careful that you don’t melt/burn the connector:-)
完成的
添加一条评论
添加你的答案
Andrew2022 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 87
