跳转到主内容
Repair guides and support for Lenovo's line of consumer-oriented laptops, the IdeaPad series, first announced January 2008.
604 个问题 查看全部
Wifi schematic for Lenovo IdeaPad C340-14API
Looking for schematic diagram for wifi. Changed the wifi card but still not working. Does anyone have the schematic so I can check the circuitry
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
WNFQ-258ACN(BT) 802.11ac/a/b/g/n WiFi + Bluetooth Combo, M.2 2230 A / E Key Module, WiFi 5, Qualcomm QCA6174A, 2T2R, Sparklan
完成的
添加一条评论
2个答案
已选择的解决方案
@jaco1 see if this schematic will work for you. I do not have a boardview for this. Let us know what numbers you have on your motherboard. Should be a Compal motherboard number
If you can't see enough when clicking on the image, you can download the image and zoom in with your image software
这个答案有帮助吗?
得分 1
1条评论:
Thank you very much oldturkey, when I get back home I will delve deeper and see if I can locate problem.
J
完成的
添加一条评论
Hi @jaco1
Is the WLAN Network adapter being shown in Device Manager?
If not and if you haven't already done so, check in BIOS for a WLAN enable/disable setting and check that it is enabled.
Most laptops have this setting, usually it is found under the Security or Advanced tab in BIOS. (The manual for your model doesn't show any BIOS settings)
If it is shown in Device Manager what is its status? Right click on the entry > Properties > General tab > Device status box.
If it states that "This device is working OK" check that the airplane mode has not been selected. Go to Settings > Network & Internet > Airplane mode
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 114
