跳转到主内容
The Mavic air with its glorious camera, this drone is a great start for beginners to learn how to fly.
2 个问题 查看全部
Crashed into salt water…
Crashed magic air into salt water. Tried drying it out with hair dryer immediately. Let dry overnight. Tried flying again a few days later. No response. DJI wants 400$ to refurbish it. I’m a diy guy. Can someone guide me on repairing the drone myself.
Thanks JTG
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @hardrock60
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the drone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your drone and then remove the battery as soon as possible from the drone to minimize any further damage.
Then you need to dis-assemble the rest of the drone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the drone might possibly work correctly again.
Here is a link to a teardown video that may help.
If this process seems too daunting, take your drone to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair.
这个答案有帮助吗?
得分 4
1条评论:
@jayeff , much thanks for your insight. I will do my best to follow your lead. Have a great day.
完成的
添加一条评论
添加你的答案
JOHN THOMAS GRIFFITH 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 201
