跳转到主内容
加入维修社区 - 创建账户
采用抗水材料制成,配有弹性头带的小型黑色头灯。
Why is my headlamp not turning off when rotating to off position
why is my headlamp not turning off?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
I have the same problem. The head lamp is over 25 years old. It does not have a sliding or push button switch. It has been years since I used the lamp, but I thought it turned off and on by turning the head lamp bezel; however, the bulb comes on as soon as I put in the batteries and turning the bezel does nothing.
完成的
添加一条评论
1个答案
@deboya sounds like a bad switch. Check the contacts to make sure the switch opens those. Since we don't see what you see it will be up to you to troubleshoot the switch or you can try and post images of what the contacts look like etc. with your QUESTION so that we see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dave 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 17
总计 276
